It is currently Sat Jul 26, 2025 8:13 am
PostPosted: Tue May 23, 2006 8:51 am
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
Hi all,
I'm planning on building an OM-42 style guitar this summer and I
wanted to ask for any tips / hints on inlaying the mitered pearl and
purflings around the fingerboard extension.
Louis
- Louis Freilicher
PostPosted: Tue May 23, 2006 10:20 am
actually this is very simple. I use abalam but the techniques are the same for solid pearl. Use a teflon fill strip and you use that when binding. When you are ready to put in the pearl you lift the poly out and start laying the pearl.
I use elmers white glue then once I am done I will drop fill with CA to fill voids in the pearl
john hall
PS to cut the miter i use a fine 2nd cut mill file after I use a toe nail clipper to cut to aproximate length. Clipper was never used on toes
PostPosted: Tue May 23, 2006 10:44 am
First name: Louis
City: Belchertown
State: MA
Thanks for the tips John. When you rout the slots around the
fingerboard for pearl / purfling do you undercut the whole
fingerboard extension area and fill the gap with an ebony veneer?
Louis
- Louis Freilicher
PostPosted: Thu May 25, 2006 8:46 am
HI
Yes I do . This allows for future repair and adjustments at neck set time if need be
PostPosted: Thu May 25, 2006 8:51 am
First name: Louis
City: Belchertown
State: MA
Thanks again John!
Louis
- Louis Freilicher
